hi i'm new ,and like to ask for your help..
Discussion in 'CNC Mills/Routers' started by ccfly, Sep 6, 2017.
  1. ccfly
    ccfly New
    well i need help .
    i want to build small cnc machine like chinese 5axis 3040
    but to be able to cut some softer steel like st35 or 16mo3 ...
    dimensions i kinda need are in range of that 3040 cnc
    but reading a loot that cn cnc is junk at best ...week non precise drivers mbo is like women
    one day work ok ,other wont next one work a bit stops work ...
    to get some what better cnc i need 500€ driver mbo
    then i need better stiff parts ,and in all i need new cnc ...
    and other thing is to build one that have movable hand like 5AXISMAKER
    just smaller and cheeper :) 5k for plastic soft wood toy is huh
    help
  2. ccfly
    ccfly New
    i did but that one is 5000$ + she 100% cant do iron steel...
    only soft alu ,copper etc
  3. David the swarfer
    if you want to cut steel then you need something like the mills from
    Tormach Personal CNC (PCNC) | Small CNC Machines
    or build your own like this
    steel is much harder to cut than copper/aluminum, and you need a much heavier and stiffer machine to do it.
  4. ccfly
    ccfly New
    nice ,but that thing is hugeeeeee
    compared to mini mills this can mill titan 5mmper run easy
    i got question
    do you know which ox builds will be easy converted to all metal/steel build vs all alu/wood ?
    and to be possible to add 4th axis thing
    --------- ---(Tailstock CNC Rotary Axis 4th Axis A Axis 4Jaw 100mm Chuck Rotational Axis Table | eBay)
    -----something like this -----
    i look prolly 30 of ox designs but i just don't have clue ,,all these builds look weak vs one on video :)
    i was thinking to use steal square pipes ,with steel plate for rest parts cca 10mm tick
    and to weld table like 6mm bottom plate then 10mm lines that have welded 5mm "tape" over
    to look like t slots
    #4 ccfly, Sep 23, 2017
