Help with VFD
Discussion in 'General Electronics' started by adambrum, Aug 10, 2017.
  1. adambrum
    adambrum Well-Known
    My 0.8kw and VFD are on ther way and i need to start thinking about wiring the thing up.
    Im happy enough with the main wiring shielding ect but not so sure on the control side of things.
    I will be controlling the vfd from and arduino running GRBL, This is where im getting a little stuck.
    Im going to use 0-10v to control speed with a simple op amp circuit but not sure how the forward reverse and spindle enable are used.
    I can see from the manual that its expecting 24v control signal for forward and the same for reverse so would i need a relay to control these or does a 0-10v do all of it for me
    Thanks Adam
  2. adambrum
    adambrum Well-Known
    I now have my VFD and its not quite what i expected,
    its a isacon which looks to be a copy of a huanyang, ive looked at thee pcb etc and it looks well made.
    I have found one small issue so far, if the minimum speed is set to 120hz as recommended for the huanyand it ignores the acceleration as shoots straight up to speed.
    On the plus side i have been playing with speed control from an arduino and it quite happily works on 5v pwm, i have put a cap in just to smooth it but that's a bonus. need to get my good meter but it looks as if its only pulling 0.1ma.
    looks like fwd and rev can also be driven straight from the arduino as it switches to ground
  3. Gary Caruso
    Gary Caruso Veteran
    I think most people never use reverse and just wire that for forward operation.
    unless you re-scale the 0-10v input you will never get full RPM using the 5v pwm off the arduino pin.. which might be acceptable for most jobs :)
  4. adambrum
    adambrum Well-Known
    I did notice i cant get the full 400hz but i dont think im going to need 24000rpm
    Thinking of running an op amp anyway so this may fix it
  • About Us
  • Like us on Facebook
    Donate to FairShare!
