Help setting up SLA 3D Printer with NanoDLP
Discussion in '3D printers' started by 3DPiper, Jun 8, 2017.
  1. 3DPiper
    3DPiper New
    I am working on a SLA 3D Printer. It is using the Openbuilds V-Slot Nema 17 Linear Actuator:
    V-Slot™ NEMA 17 Linear Actuator Bundle (Lead Screw)
    I have an Arduino Mega/Ramps 1.4 using Repetier firmware hooked up to my Windows ultrabook. This works well with Creation Workshop.
    I would like to try NanoDLP (still on my ultrabook, not raspberry pi), but I know I have to use Marlin firmware on the Arduino/ramps. I worked with it for a bit, but I can't figure out what board to select in the configuration. The only control I need is for 1 z-axis stepper motor, two end stops, and a project lamp on/off. I don't see any boards in the configuration file that match that.
    Has anyone gotten the Openbuilds V-Slot Nema 17 linear actuator to work with NanoDLP via ArduinoMega/Ramps?
