Heavy duty C Beam
Discussion in 'CNC Mills/Routers' started by DA_Spec, Sep 8, 2017.
  1. DA_Spec
    DA_Spec Well-Known
    DA_Spec published a new build:
    GrayUK likes this.
  2. DA_Spec
    DA_Spec Well-Known
    Just received my proximity sensor so i designed some mounting plate to put at the end of the Cbeam and printed them overnight second design was perfect thefirst i didnt think about the rail thickness and too much bolt hole for nothing
  3. Gary Caruso
    Gary Caruso Veteran
    Cool build, is that cncrouterparts rack and pinion?
  4. DA_Spec
    DA_Spec Well-Known
    Yes the pro rack and pinion system with nema 23 and 3/8 pulley
  5. Gary Caruso
    Gary Caruso Veteran
    Nice, i would love to see more pics like of the gantry and how you did the x axis rack engagement.
  6. DA_Spec
    DA_Spec Well-Known
    It has a 1 inch mdf piece bracing the 2 cbeam together in the back...everything will be cut in 3/4 inch 6061 when the design will be final...
