Extrusion idea
Discussion in 'General Talk' started by Anthony Bolgar, May 26, 2017.
Would you want the choice of a Cbeam of 100mm X 60mm
Poll closed Jun 16, 2017.
  1. Yes
    4 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. Anthony Bolgar
    Anthony Bolgar Journeyman
    How hard would it be to add something like the C-beam to the product line, but in a size of 100mm X 60mm ? The strength and stiffness increase would allow for some pretty powerful machines. Many of the machine designs using C-beam would translate fairly easily to this size. And instead of using 6mm Aluminum for the plates, the new size would benefit from using 8 or 9mm plates.
    If you're going to 60mm wide, you'd be better off going with an I-beam configuration.
  3. Anthony Bolgar
    The 60mm is the two sides of the cbeam, 100mm is the distance across the wide flat.
