DIY LED acrylic lamp
Discussion in 'Laser Cutters' started by quyngan, Apr 4, 2017.
  1. quyngan
    quyngan New
    quyngan published a new build:
  2. Giarc
    I would love to know what bit, spindle rpms, and feed rate you used for cutting the acrylic.
  3. quyngan
    quyngan New
    I've changed a little bit. the acrylic is tough for cnc spindle but it could be easily cut by laser.
    I've use 300mm/min feed rate and 4000rpms spindle. But the quality of the edges of the acrylic after cut is totally disaster.
  4. Kevon Ritter
    Kevon Ritter Veteran
    Cutting acrylic on a CNC is a piece of cake. When dealing with plastics, heat is your enemy. To help with that, you want to remove chips. An o-flute is the only endmill I use in plastics of any kind (except HDPE). I have a router. I believe I had it set to 20k rpm, 1000mm/min feed, 300mm/min plunge, and a 2mm max DOC. Holding the work piece starts to become a struggle after this point for me.
