CNC xPro V2
Discussion in 'Controller Boards' started by Paul Stoller, May 13, 2016.
  1. Paul Stoller
    Paul Stoller Journeyman
    Does anyone know if the xPro can be used to run external drivers. I like the board well enough but I will need more current capacity than what the onboard drivers are limited to.
  2. Paul Stoller
    Does anyone have any other suggestions for boards that will accept external drivers (that are not Breakout Boards, I'm trying to avoid Mach 3, I do not want to be reliant on a parallel port).
    I'm currently looking at the following three boards.
    CNC xPRO V2
    CNC xPRO V2 Controller Stepper Driver
    I'm considering this board as it's sold through the parts store and we seem to have some folks on the forums that are using it.
    Smoothie Board 4X
    Smoothieboard - Smoothie Project
    I really like this board, the fact it is open hardware is appealing to me, but they are currently out of stock in North America.
    PiBot
    PiBot Controller Board Rev2.0 (CNC and 3D Printer 2 in 1)
    This board seems interesting, but I'm looking for some feedback from anyone that's actually used one.
  3. Ronald van Arkel
  4. Paul Stoller
    Thank you for the info, I had come across the protoneer shield for the raspberry pi not too long ago, but wasn't sure how hard it would be to wire it up to external drivers. I really like the idea of going that route as the Pi can add a lot of nice connectivity options to the machine.
  5. Ronald van Arkel
    O yes, for sure. I'm using a net-book (Atom 1.6Ghz, 2GB, 10" screen) for communication and I'm going to use the G-code "sender" build into ESTLCAM.
