CNC X Axis Opinion
Discussion in 'CNC Mills/Routers' started by xeudoxus, Apr 14, 2017.
Which Version would you build?
  1. V1 (OpenBuilds c-Beam)
    0 vote(s)
    0.0%
  2. V2 (8020 30-6060 Outer)
    0 vote(s)
    0.0%
  3. V3 (8020 30-6060 Inner)
    0 vote(s)
    0.0%
  4. V4 (8020 40-8080 Inner)
    0 vote(s)
    0.0%
  5. V5 (8020 40-4080 Inner)
    0 vote(s)
    0.0%
  1. xeudoxus
    xeudoxus New
    I am designing a CNC for light aluminum work. I have made 4 examples and cannot figure out which one to use. Price wise, it is about the same, the openbuilds c-beam version (#1) would be about 60% cheaper to build. It's my first build/revision.
    (File is Sketchup 2017)
    Thanks,
    -Matt
    #1 xeudoxus, Apr 14, 2017
  2. Kevon Ritter
    Kevon Ritter Veteran
    If you aren't going to use v wheels, you might as well build up. The v wheel setup is waaaaay cheaper. I just went through all of the same design thoughts too. I did go with the c beam since I intend on cutting smaller aluminum parts. The larger the machine gets, the weaker it becomes, but even flimsy materials can be strong at small sizes.
  3. xeudoxus
    xeudoxus New
    Agreed, I went through the v-wheel option, then the bar linear bearings, then the hiwin stuff. Now I know I want the 20mm Hiwin and 15mm grounded ball screw. I just don't know which frame/design to use.
  4. Kevon Ritter
    You might as well use 40 series with that gear.
  5. xeudoxus
    xeudoxus New
    40 Series ball?
  6. Kevon Ritter
    40 series 8020
    10 and 15 are imperial (1" and 1.5")
    20, 25, 30, 40, and 45 are metric
  7. xeudoxus
    xeudoxus New
    I was thinking of using the 40 series and doing a 40-8080 frame (the 40's have more accessories compared to the 30's) but, I was thinking the 30-6060 would be more compact (with most of the gears/motor being around 60mm). Ill draw one up with the 40-8080 real quick.
  8. xeudoxus
    xeudoxus New
    Updated the original files for the 40-8080
