CNC Hot Wire Cutter 4 Axis for Cutting Foam Wings
Discussion in 'Other Builds' started by Rusticalmond, Aug 27, 2015.
  1. Rusticalmond
    4 Prong Aviation Plugs installed for motor quick Disconnects.
    Also had a dead rat hit me in the head Friday while running cable.
  2. Rusticalmond
    I have used aviation plugs to make quick disconnect cables for my 4 steeper motors.
  3. pieri70
    pieri70 New
    Hello
    I made my CNC 4 axis foam cutter with cheap mechanics and a controller called Theremino (really cheap and powerful USB controller).
    theremino | the real modular input output
    Here my super simple CNC controller...
    It is natively supported by DevCad softwares I use devfus and devwing foam to design my foam fuselages and wings.
    You can also use other softwares (es GMFC and others) and Theremino has its own Free open source CNC control software (i.e. ThereminoCNC).
    You can use thereminoCNC instead of Mach3 to execure GCode files, or use DevCNC foam that has 3D view of the entire cutting process and many other useful tools.
    I'm really happy with my setup.
    Here is the discussion on RCGroups
    Simple but mighty DIY 4 axis CNC Foam Cutter - Theremino Controller (Not Arduino)! - RC Groups
    Just a question
    I just purchased 2 meters of 20x80mm V-Slot profile to upgrade my X axis.
    I would like to use the Openbuild Plate and solid V-Wheel with timing belt and 16 teeth pulley with Nema17 direct drive. Do you think the motor will have enough torque to move my X axis?
    #63 pieri70, Jan 18, 2016
  4. Ghasemi
    Ghasemi New
    Dear all
    I kindly need your helps to fix my software controller issue with my hotwire foam cutting machine.
    I used the XproV4 spark concepts controller and the open build opensourse controller software but i donot have the gbrl with customized setting to flash the controller board also if you know any better controller software for this purpose please let me know.
    i have 4 stepper motor ,X and Y in each side ,bith X and both Y works synchronized .
    Thank you
    You can use the SLAVE driver to run one of the slaves, but you'd need to wire the other motor (one with lower load) in parallel on one driver (or add external drivers: DQ542MA Stepper Motor Driver)
  6. Ghasemi
    Ghasemi New
    Thanks for reply,actually i did already and i do not have issue with running motors ,my problem is i need a gbrl setting for XproV4 controller for hot wire cutter which is not in open build controller machine list and also Gcode converter for this specific machine with only X and Y
    Thanks again
    #66 Ghasemi, May 13, 2019
    You can use the Grbl documentation (github.com/gnea/grbl/wiki) for help setting up firmware.
    We only have profiles for machine bundles we designed/sell but you can use those as a base to start from.
    #67 Peter Van Der Walt, May 14, 2019
    Check out Home
