C-Beam Sphinx with a twist
Discussion in 'CNC Mills/Routers' started by SamKircher, Aug 9, 2017.
  1. SamKircher
    SamKircher published a new build:
  2. MaryD
    MaryD OpenBuilds Team
    Following :)
  3. Mark Carew
    Never to young to build! Awesome to see you have some help:thumbsup: have fun
  4. SamKircher
    Thanks guys!
    So I have been trying all day to get bCNC to just connect to the phoenix control board with no luck. It just doesn't show up in the com ports at all, even though the computer is showing it is connected in device manager.
    Very confused and have no idea what I am doing, any help would be great.
  5. cmwwebfx
    cmwwebfx New
    Good looking build. Do you think it is sufficient to build the Sphynx out of MDF as a start to then be able to cut our own alloy plates from a machine built with MDF?
  6. SamKircher
    I probably wouldn't go straight to aluminum from mdf. Its just not stiff enough.
    cmwwebfx likes this.
  7. cmwwebfx
    cmwwebfx New
    Ahh ok, I was thinking that the MDF might hold up enough to upgrade itself by cutting its own upgrade parts from alloy. Am trying to figure a way to do the aloy parts without finding someone else to do them.
  8. Scotty Orr
    Scotty Orr Journeyman
    If the MDF is accurate enough to properly locate the holes (or to cut a thin template material), I don't see why you couldn't do that, and finish an initial alloy set on the band saw and drill press (if you have those).
  9. SamKircher
    Second what Scotty said, use it to spot your holes etc, then drill out on the drill press, then cut none critical geometry by hand. If you are like me your final plates won't be even close to what you thought when you started, so maybe cut some test ones with your CNC out of mdf, and make your alloy ones the third set. My set right now are acrylic which is pretty stiff, but has its downsides. Looks nice though.
  10. GrayUK
    I used a set of very rigid 12mm plastic chopping boards to get started. :D
    Easy to cut and make, and lasted well enough to very gently make the ali plates. :thumbsup:
  11. cmwwebfx
    cmwwebfx New
    Genius idea.
  12. Hayri PhoenixCNC
    Hi Sam,
    This is Hayri maker of the Phoenix CNC Controller, I know this is an older post but if you still need any help please let me know.
