BldrBot Pro
Discussion in '3D printers' started by Keith Davis, Nov 13, 2014.
  1. Keith Davis
    Keith Davis Veteran
    Keith Davis published a new build:
  2. TechGirl
    TechGirl New
    Hi Keith,
    I'm intrested in building a Bldrbot Pro to replace my Prusa i3. I can get all the dimentions for the printer from the .skp file, all the dimentions but one. In the pictures you state that the Z drive belts are closed loop belts from RobotDigg, my question is, what length are the belts?
    Regards
    Sally
  3. Keith Davis
    Keith Davis Veteran
  4. TechGirl
    TechGirl New
    Thanks for that Keith
  5. Redmayne
    Redmayne New
    Surprised this didn't get much attention. Any more updates? This machine is very logical to me. Would love to know if you've fleshed this put further.
    I too have been planning on using the double ended nema. It could also be used for the x or y gantries in an ultimaker type setup as well. I think the fabrikator from turnigy uses something similar for their y movement.
  6. Keith Davis
    Keith Davis Veteran
    When I put the BOM together for this, it was more expensive than an alternate design I had. So I built the other one.
