Belt & Pinion Example
Discussion in 'Other Builds' started by Mark Carew, Nov 10, 2013.
  1. Rick 2.0
    Does the belt fit easily between the sides of the V-track? In the photos, it looks to be too wide.
    I have to agree with the others suggesting solid wheels. That will spread the pressure across the belt better. You can see how much it is flexing between the points of the V-wheels.
  2. Mark Carew
    The new belt does @ 5mm width :) We noticed this happening on the old 6mm wide belt and moved to cut a half millimeter off on each side and this leaves room for the belt to lay in the track with out any obstructions.
  3. CutAboveZ
    CutAboveZ New
    Ha! good one!
    Back to the drawing mouse pad :)
    Thanks!
  4. Mark Carew
    The model located in the Files tab above for this build, has been updated with the OpenBuilds Solid V Wheels This system works awesome with these :thumbsup:
  5. dddman
    dddman Journeyman
    How did you cut a half millimeter of the belt?
  6. Mark Carew
    With a belt slicing machine :) Well really our manufacturer does it for us on these special order belts.
  7. Robert J Rissell
    Coming in late.. Maybe just an observation but the original concept looks to have 2 differences... One: The idler pulleys on kram242 seem to be further apart and closer in the Z direction; having the end effect that the belt is at a 45 degree angle as opposed to the nearly 90 degree angle seen in Robert's example picture. This would have a < 160 degree wrap on the pinion and less than 90 degree contact area on the idlers.
    Perhaps this results in less friction and wear?
    Two: The original example of the double v-wheel would seem to eliminate (or minimize) the drifting of the belt from side-to-side.
  8. Razzys
    Razzys New
    Has anyone tried this system using GT3 belts?
  9. Mark Carew
    Yes, I have the GT3 pulleys and GT3 belt on my OX build in place of the GT2 and I have to say its a much more robust system because of the GT3 belts.
    Hope this helps
    Mark
    crispin likes this.
  10. G-Force
    G-Force New
    Hi Mark,
    Just new to the GT3 belt drive, but I am wondering how you join them in a build? Am about to order some parts, but not sure about this part of it.
    Any help here would be great.
    Thanks.
    Glen
  11. GrayUK
    The reply, as in the other similar post you have made, is the same.
    The belts are not joined, but clamped, in one form or another, at each end of the v-slot run, after being threaded around the pinion wheel. Be that X axis or Y axis.
    Nowadays the 1st belt, is accompanied by another belt, which is laid within the slotted aluminium beneath the other, creating a "rack and pinion" effect.
    Please try to read, and take a look at some of the videos, on the Forum, to give you a better idea of how the various CNC set-ups works.
    Gray
  12. Darren Ditto
    I'm just going down this route now with my build. I'm using belt and pinion with mini-wheels. Thinking I may have to redesign how the belt is held in place based on what I am reading here. (When I try to tighten the screw it rotates the belt out of alignment so I can't get a belt that is super tight and also in alignment.) I like what Robert is doing. I might have to rig up something like that and have the belts pass outside of the case and loop back in where they are attached.
    GrayUK and Mark Carew like this.
  13. R_B
    R_B New
    I agree, the wheels run in a groove that they contact at a smaller diameter than their full rolling diameter - which translates to rolling circumferences.
    There is either belt slip on the wheels or wheel skid in the grooves - wear patterns should indicate which.
    How much, how significant and whether this is a good or bad thing... more thunking required.
    i.e. might it put some drag tension into the system and reduce backlash/slop ?
  14. Mark Carew
    I see what you mean by this, but to be honest we have not noticed any issues like this to date and all the systems we have used the belt an pinion for have been working great. From super accurate 3D printers to lasers to routers with no problems.
    However adding idlers would not be too difficult for these and may be the best way to build it to ensure no worries here.
    Good thinking guys, thanks for the feedback :thumbsup:
    Mark
  15. jkmcc13
    jkmcc13 New
    First post here,
    Looking to use this setup on my 3d printer design. Looking to use this for a crane style z axis.
    What kind of resolution you guys able to get and do you think a nema 17 will have enough torque to lift vertically? I don't need speed : ) I'll try to do the math, but not sure I can figure it out haha
  16. finalcountdown
    What is the advantage/disadvantage of using vslot aluminium as a gantry plate (please see the attached)?
    Does it make it more stronger, durable?
  17. Haqeekjavid Shaikh
    i wanted to use it for my 3d printer ..... wud it make a gud z axis ??? ..... i mean wud it hold the extruder ...... wud it effect the resolution ???........ using it instead of lead screw .!!
    pls help .... thank you
  18. Ben Streeter
    Late to the party, but these posts have all made me think harder about how this nice little actuator....err....actuates. I agree that mis-matched v-groove pulleys and pinion diameter will cause the wheels to skid or belt to slip agianst the v-groove pulleys. I was thinking there might be another explanation....if v-goove pulleys are used allowing the belt to pull inwards into the groove, does it pull in and sort of 'auto adjust' until it finds the equivalent diameter where the belt wont slip/wheels wont slip any more? Kind of like the pulley in a constantly variable transmission (CVT)? The effective diameter of the pulley is reduced because the belt is pulled in to its groove?
    Just thinking out loud. I really like this concept....it is allowing me to make a nice tight gantry for a project. I love openbuilds in general. Great stuff!
  19. Ben Streeter
    A little more information about the type/configuration of printer you are making would make your question easier to attempt to answer.
