Ask Grbl CNC questions here.
  1. nikki81
    nikki81 New
    I have built a corexy drawbot like the axidraw but i am having a few problems getting grbl to work correctly. Everything is working but after homing when i send a g code file it is going to the opposite ends of the axis instead of starting from its home position. I have it setup so that + is away from the endstop and - is towards the endstop.Any help you can give me will be much appreciated as i have been struggling with this for a few days now and not made any headway.
    Thanks Nikki
  2. DaveH24
    DaveH24 New
    Hi Nikki,
    Can you explain what you have done to set up the direction ?
    Also what happens if you don't home , but move to the home position , then run the g-code ?
    I also note that that there are some comments regarding HOMING and COREXY in the config.h file ,ie the default
    homing is incompatible with corexy , have you changed this.
    Hope this is of some use.
    Regards
    Dave
  3. Cabrunco
    Cabrunco New
    Hi all, a very basic question. Which boards are compatible with GRBL? I know of one, its name is "woodpecker CNC GRBL 0.9 . I like this board, it controls 3 motors very easily, but I would like to know if I have options. Thanks!
  4. nikki81
    nikki81 New
    Hi i have changed the config.h file for homing corexy. when i don't home it and send the g-code it is still moving to the maximum extremes of both axis. Ive attached my config.h file and my grbl $$ settings.
    Thanks Nikki
  5. nikki81
    nikki81 New
    I have found my problem. because i am use to using octoprint i forgot to check if the g code sender was at zero when i reset it to zero it works perfectly
    thanks nikki
    Mark Carew and David the swarfer like this.
  6. Marklc
    Marklc New
    I have done this
    a dozen times keeps takin me to a video .. where are the files ???
    this site is frustrating
  7. David the swarfer
    yeah, I cant find it either. maybe @Metalguru can provide links?
    however, you want the latest versions anyway....
    Universal Gcode Sender Download - UGS
    GRBL panel Releases · gerritv/Grbl-Panel · GitHub
    GRBL v1.1 Releases · gnea/grbl · GitHub
    Arduino IDE Arduino - Donate
    First install the Arduino IDE
    Use that to upgrade your controller to GRBL v.1.1 (follow these instructions)
    Then use UGS to set up and test.
    Then you can try GRBL-Panel to see if you prefer that GUI to UGS.
    You can also try Candle Releases · Denvi/Candle · GitHub which integrates nicely with SketchUcam, video coming soon....
    Note that not many of the GUI's are compatible with GRBL v1.1. The ones I have listed I have tested myself and do work.
  8. David the swarfer
    good
    I saw this somewhere else the other day.
    Why are you homing twice? Homing RESETS stuff in the controller. You only need to do it after power on, after that everything is done in work co-ordinates.
    are you working in inches or millimeters in Sketchup? 'much larger' usually means the controller is in inch mode (G20) but is getting measurements in millimeters. make sure it is getting a G21 if it is getting millimeters sent to it.
    Have you calibrated? By this I mean, if you give it a manual command like
    G21 G91 G0 X100
    will it actually move exactly 100mm on X?
  9. DaveH24
    DaveH24 New
    Hi ,
    I'm currently working on controlling a VFD spindle over its RS485 interface . I note that it takes about 20 seconds to run up to speed, So I assume , the M3 SXXX command should block until the spindle has run up to speed , Is this the expected behaviour .
    Many Thanks
    Dave
  10. Metalguru
    Metalguru Veteran
    Well, it used to be there... As we both pointed out, those versions are getting a bit long in the tooth anyway, the newer versions are much better. Thanks for the links, David.
    BTW, I use Xloader to load GRBL into the arduino, much easier and faster than using the Arduino IDE.
    XLoader
    MG
  11. Edi
    Edi New
    Today I have started to have a problem that when started homing it seems that the machine resets the machine coordinates BEFORE it finish the homing procedure just before homing debounce and gives me negative coordinates. Does anyone know what is going on?
    Machine coordinate goes like this:
    X axis limit - 1mm (in my example -879),
    Y -1 and
    Z -1.
    Earlier today it all worked fine
    Any ideas?
  12. HPB
    HPB Well-Known
    @Sonny Jeon Hi. I've run grbl primarily on the Atmega328p and I was wondering if it is possible to run this on a 32-bit processor running at much higher clock speed (near about 100Mhz) than the AVR at 16MHz. If it indeed is possible, is there any benefit to doing this?
  13. Edi
    Edi New
    So after three frustrating days and after numerous trials and errors it seems that the problem solved uncommenting #define HOMING_FORCE_SET_ORIGIN in config.h
    Hope it helps someone with the same problem.
  14. Metalguru
    Metalguru Veteran
    Yeah, I tried to use that define as well, and had no luck with it. As you pointed out, the Y axis set to zero as expected, but the X axis still shows a large negative number. They are both supposed to set to zero. Perhaps put in a bug report on the GitHub page for GRBL, Sonny might fix it.
    MG
  15. David the swarfer
    GRBL 1.1is the last release for the 328p processor.
    The next version will run on an ARM processor.
    GitHub - gnea/gnea: An open source, embedded, high performance g-code-parser and CNC milling controller written in optimized C that will run on a straight Arduino. (ARM-version!)
  16. HPB
    HPB Well-Known
    #526 HPB, Mar 18, 2017
  17. David the swarfer
    'soon' they say.
    as to hardware, only Sonny knows for sure (-:
    HPB likes this.
  18. DaveH24
    DaveH24 New
    Hi all
    As I have previously mentioned , I'm implementing the control of a Huan Yang VFD over RS485 for use with grbl-Mega.
    I now have the basic system running, I'm able to start, stop and set the speed of the VFD , blocking any further commands from being processed until the requested speed is reached.
    Also if It fails to reach the required speed, with in a time limit , it will set an alarm and attempt to stop the motor, At the moment , all the parameters for the drive have to be set up on its control panel .
    I've yet to cut anything but air :( but I will set it to work next week.
    If anyone is interested in having a go , with this, please let me know , and I'll make it available once I've cleaned up the code. I'll probably be able to make this available as a patch to grbl-Mega.
    It is mainly additional files with additions to spindle.c and a call to initialise the serial comms in main.c , I've also used a second serial port for logging /debugging purposes , but this will not be required after setup.
    Hope this is of interest to someone out there :)
    Best Regards
    Dave
  19. matthew clarke
    Hi All. Having a bit of a strange issue here. My Z Axis ignores my settings and does as it pleases. What I mean buy that is if I set the Z Axis to invert via the tick box or the invert mask and use the jog buttons it does as required. However when I load my G-Code, if it reads Z5 it will push into my stock rather than retract up 5mm. So I invert the axis and it will do the same. If I manually edit every Z line in the code it all works well. So it seems that when it reads the Z line in the G-Code it is ignoring my settings.
    I am about to pull the last strands of hair out and any advice would be appreciated.
    I have not included the settings as it seems to make no difference what i set my invert mask to.
  20. David the swarfer
    forget tick boxes and jog buttons and make changes directly: (you dont tell us what GUI you are using)
    Grbl v1.1 Configuration · gnea/grbl Wiki · GitHub
    $3=4
    will invert only Z.
    then, give a manual command to check movement
    G91 G21 G0 Z5
    should move it 5mm away from the workpiece.
    and
    G91 G21 G0 Z-5
    should move it 5mm toward the workpiece.
    AFTER this proves to work correctly you can try the GUI jog controls and check that they work correctly, but Gcode is going to do what the above code does so if jogging goes in the 'wrong' direction you need to fix the jog buttons, not the invert mask.
    and, please post the Gcode so we can check that....
  21. matthew clarke
    Beautiful I will give it a crack to night and let you know. I will also make sure to upload said examples. Thanks for the Quick reply.
  22. matthew clarke
    Well. I fairly certain I manged to download the GBRL equivalent of a knock off star wars figurine that you bought from a guy round the back of a pub. It says official but was not. Any woo a few large glasses of wine and full reload of GBRL and a new Arduino UNO and she sings like that kid from the Voice, you know the one the one that is actually good.
    I very much appreciate the help.
    Matt
  23. charles moncavage
  24. charles moncavage
    Hi,
    I have been trying to configure a simple and reliable wireless cnc plotter setup. Basically need to take bmp, svg file from android to plotter for outline print like with a vinyl cutter. As a matter of fact our original proto was controlled from a stepper board out of a plotter/cutter and worked well but now needs to be off-the-shelf electronics (for the most part), reproducible and wireless.
    Tried a MakeBlock app XY-Plotter Application for Andoid that looks perfect for our application but no evidence that the app even works.
    Any ideas? Also, how can I find someone to work on these type of projects on a regular basis for compensation?
    Thanks Much!
    Charlie
  25. asterix
    asterix New
    Hi Sonny,
    Many thanks for all your effort with GRBL, I think its such a great project!
    I've got my GRBL 0.9 running on an Uno and then I have a cnc shield on top of it, for easy plugging in of stepper driver boards. The shield is here: Arduino CNC Shield V3.XX – Assembly Guide | Protoneer.co.nz
    What I would like to do is switch my spindle on and off through a relay when the gcode sends an M3/M5 command. No PWM or anything, just drive a relay through a pin going high and low at the beginning and end of a gcode file.
    The spindle enable pin and the spindle direction pin seems to be staying high, regardless of whether I send an M3/M4 or M5 command through Universal G code sender.
    Is there some setting which I need to change in the grbl configuration before I can get this to work?
  26. DaveH24
    DaveH24 New
    Hi Asterix
    try specifiying a speed after the command , I found I had to do this for the relevant functions to be called , even though I was ignoring the speed at that time.
    eg:
    M3 S1000
    M5 S0
    Regards
    Dave
  27. HPB
    HPB Well-Known
    You'll need to connect your relay using a transistor as described here. If you are using grbl v1.1, you need to specify a S value along with the M3 command to turn the PWM pin HIGH. If you've not tampered with the default values then its M3 S1000 to turn ON and M5 to turn OFF.
  28. asterix
    asterix New
    Thanks HPB, I have a board like this, which can switch 10A at 220V, off a 5V signal. So all I need is the 5V, 0V signal.
  29. asterix
    asterix New
    Thanks Dave, I will give this a try. I am also uninterested in the speed commands; but if that is what is required then that is great.
  30. HPB
    HPB Well-Known
    Yep that would work. Good luck.
