Ask Grbl CNC questions here.
  1. Sonny Jeon
    Sonny Jeon Well-Known
    It might be helpful if you explained what went wrong with your machine earlier when you first posted about this problem. You "forced" your y-axis to home? What was the initial problem that caused you to "force" anything? What did you do to try to fix it? I'm think you may have fried something, because Grbl's settings should not be randomly resetting itself. Also, make sure you are using the most recent release, Grbl v1.1f
  2. Metalguru
    Metalguru Veteran
    Cool, thanks. Now I have to figure out how to compile the source...
    Is there a way to dump or extract the settings on an existing install to a new default.h file (or other file)?
    MG
  3. Metalguru
    Metalguru Veteran
    Where do I find this script?
    MG
  4. Stephan Schmidl
    Hi Sonny,
    Forced is maybe not the right word, I only gave the machine the grbl command.
    That had been the same issue....grbl lost my inputs and showed some kind of standard settings, not the ones, I programmed to fit my machine.
    By the way...is there a grbl command to lock the stepper motors?
    The ox seems to be very wobbly, when powered up.
    I could easily move the axis by hand, I think that is not very beneficial, when it comes to accuracy.
  5. Sonny Jeon
    Yes. It's in the Wiki page that explains the configuration of Grbl. Setting $1=255 will keep the steppers enabled.
  6. Stephan Schmidl
    By the way...Sonny, you mentioned the cnc x pro could be accidently been fried?
    What could be reasons for that?
    I can't imagine to do something unusual at the assembly or first runs.
  7. Martin Keatings
    I built the c-beam machine from the kit and marks video on youtube. Im now at the point where i need to setup grbl and mark keeps referencing "software" folder in the viideo and an image with the grbl settings but I never got any of that in the pack. Can you point me in the right direction?
    Martin
  8. Metalguru
    Metalguru Veteran
    Martin:
    Go to the Openbuilds "Builds" page, and select "CNC Router builds" at the top. Scroll down until you find the C-Beam Machine router build. Go to the "Files" section, and download the C-Beam software zip file. This should have everything you need. Note that the versions of software here are quite old, you should go to GitHub and get the latest versions of GRBL, GRBL Panel, etc.
    MG
  9. RichGMD61
    RichGMD61 New
    Now that I've finish my testing with my 'Uno' to get my Ox up and running, which all went okay apart from a few hiccups on my part, I thought I'd like to use my 'Uno' for another project when it comes up as I've now got a dedicated board running GRBL. So I plugged in my board which had 'GRBL' on, found the com port it was on, started up the IDE, set the relevant port and tried to upload 'blink' to clear 'GRBL' off, and things didn't happen as they should have, no flashing lights on TX/RX, tried a couple of times no joy.
    I then thought lets check on UGS to see if it connects, sure enough it connected and was still able to check settings and everything, now when I checked on the 'GRBL' wiki it said this wouldn't happen.
    So what gives, do I need to get the boot-loader burnt back on again from a good Arduino or not.
  10. David the swarfer
    make sure there is nothing connected to the Uno that might prevent it resettting when the IDE tries to program it. or, press the reset button just after you press 'upload'.
    RichGMD61 likes this.
  11. Metalguru
    Metalguru Veteran
    Hey, anybody have problems installing the FTDI chip drivers in Windows 8? I have a client that can't seem to get the Arduino Nano talking to Win8. We've installed the FTDI chip drivers, tried installing the Arduino IDE, nothing seems to work. Win8 recognizes the chip is there, but wont talk to it and won't assign a COM port...
    MG
  12. RichGMD61
    RichGMD61 New
    Bit of a 'brain fart' moment again, I also had problems connecting my 3D printer as well and it wasn't until this morning when I was having my morning smoke that I realised it could be the hub I've got, sure enough not long ago uploaded 'blink' and its merrily flashing away like a mad thing. Needless to say I've now got an 'arduino boot-loader chip' on it's way to me at this moment, that'll be waiting for a project when the time arises. Ho hum.
    So the moral of the story, when something is cheap it doesn't mean its gonna be good.
  13. Saint Billy
    Pulling my hair out at the moment, can someone here save me from death by alcohol?.
    My Ox is built, has taken 6 weeks on and off, I found the mechanical build ok with not too many slip ups due to Marks excellent video. I have limit switches installed with Hard limits and Homing set on 1. The machine homes lovely with no bashing into side rails etc, it homes nicely to X,Y and Z in the positive position. I also have the Max travels set up slghtly smaller than I need to just to be safe.
    My problem arrives when I zero on a work piece which I put in the middle of the table, I reset the work area to zero and then I home it then I send the gcode at it, the ox fires up then will try and do its business nowhere near the zero location even though I know that this is roughly where it is meant to start its cut, then it will hit the limit switch and disable. Obviously I am air cutting atm but I have spent nearly 2 weeks playing with Universal gcode sender and I cannot figure it out what the issue is. I have looked on this forum for answers time and time again taking the advice of anything that relates to my problem but with no luck. The gcode I am sending it only represents a small area (aproximately 110mm x 250 mm safe area) done in Sketchucam, but the ox acts as if it is handling something much larger.
    I have checked my wiring again and again but everything runs in the correct direction so it is not that. I have played with the gcode and used different settings, defaulted the values and starting over again and again.
    It is driving me crazy as I am desperate to cut and produce but I am thwarted.
    Any good samaritan out there have the answers?
  14. Ferreri
    Ferreri New
    How are you seeing your work zero?
  15. Saint Billy
    I click reset zero in Universal Gcode sender when in work area position.
  16. Ferreri
    Ferreri New
    What happens if you set your zero, home the machine, and then send to your zero (G0X0Y0)?
  17. Peter O'Hagan
    Hi. I am seeking a little help from the group around the commissioning of my recently completed c beam xl
    I am looking for support in the grbl settings ( they are a mystery to me!) for this build
    Also the setting of the microswitches and the whole area of homing.
    Any help would be really appreciated
    P
  18. Saint Billy
    Still get the same result I'm afraid. Odd one I know.
  19. Ferreri
    Ferreri New
    When you reset zero, does UGS show you are at zero?
    Also, does UGS send a G92 or a G10 web seeing zero?
  20. Saint Billy
    Ugs resets to zero. I will check the G92 and G10 as not sure.
  21. Saint Billy
    It shows G10 but not G92. Cheers
  22. Ferreri
    Ferreri New
    Hmmm, but it goes back to home switches when you send it to your new zero? Maybe you're mixing work coordinate systems?
  23. Saint Billy
    Sorry, I may be confusing you, it will home to the correct position and it will return to zero wherever I set it, but once I have set Zero (where my workpiece is), when I run the Grbl file it starts its cut elsewhere no where near and gets stopped by hard limits otherwise it would be crashing into the side rails. The size coordinates of the file I'm sending are only small so there is no need for it to be going outa bounds.
  24. Metalguru
    Metalguru Veteran
    http://www.openbuilds.com/members/saint-billy.60317/
    Have you run your g-code through Camotics or some other simulator to see if your g-code origin is where you think it is? If you are homing at y+ max and x+ max, your origin on your g-code needs to be in the upper right corner of your code, All of your X and Y moves will be negative. Most g-code has its default origin in the lower left corner, and all moves are positive.
    Also, open up your g-code file in a text editor and manually look at the G1 X,Y co-ordinates and see if they look reasonable.
  25. Saint Billy
    I have just looked at gcode parameters and it is showing (G54:-6.000,--6.000,-1.000),
    is this correct as all the other G commands are 0.?
  26. Metalguru
    Metalguru Veteran
    G54 should be all zeros as well. Are you working in inches? Have you checked to make sure your g-code is in inches as well? And your UGS is set up for inches?
  27. Saint Billy
    Hi, I am working in metric. to be fair I mainly use the basic Universal Gcode sender which is in Metric but I didnt realise Ugs was in inches. is the G54 values messing me up? if so how do I return these to zeros. cheers
  28. Ferreri
    Ferreri New
    The G54 values show your work coordinate offsets. They should not be zero if you changed your work zero.
    Can you share your Gcode?
  29. Saint Billy
    Thanks for the time guys, appreciated!
    This is the gcode I am sending:
    (Generated by SketchUcam V1.4d-80c0152)
    (File: cncdustcollector.skp)
    (Bit diameter: 8.000mm)
    (Feed rate: 8.000mm/min)
    (Plunge Feed rate: 80.000mm/min)
    (Material Thickness: 15.000mm)
    (Material length: 250.000mm X width: 110.000mm)
    (Overhead Gantry: true)
    (Plunge Depth first)
    (Optimization is ON)
    (www.PhlatBoyz.com)
    (Loaded profile DustCollectorTestCut)
    G90 G21 G49 G17 F80
    M3 S5000
    G00 Z10.000
    X38.123 Y33.654
    G00 Z0.500
    G01 Z-15.300 F80
    X34.405 Y38.500 F7
    X32.067 Y44.144
    X31.270 Y50.200
    Z-7.500
    X31.466 Y51.687
    Z-15.300 F80
    X32.067 Y56.256 F7
    X34.405 Y61.899
    X38.123 Y66.745
    X42.969 Y70.464
    X48.613 Y72.801
    X54.669 Y73.598
    X60.725 Y72.801
    X66.368 Y70.464
    X71.214 Y66.745
    X74.933 Y61.899
    X77.270 Y56.256
    X77.872 Y51.687
    Z-7.500
    X78.068 Y50.200
    Z-15.300 F80
    X77.270 Y44.144 F7
    X74.933 Y38.500
    X71.214 Y33.654
    X66.368 Y29.936
    X60.725 Y27.598
    X54.669 Y26.801
    X48.613 Y27.598
    X42.969 Y29.936
    X38.123 Y33.654
    G00 Z10.000
    X24.617 Y11.006
    G00 Z0.500
    G01 Z-15.300 F80
    X68.175 F7
    Z-7.500
    X71.175
    Z-15.300 F80
    X84.721 F7
    X87.487 Y11.187
    X90.257 Y11.738
    X92.931 Y12.646
    X95.464 Y13.895
    X97.813 Y15.464
    X99.936 Y17.326
    X101.798 Y19.450
    X103.367 Y21.798
    X104.616 Y24.331
    X105.524 Y27.005
    X106.075 Y29.775
    X106.256 Y32.541
    Y54.667
    Z-7.500
    Y57.667
    Z-15.300 F80
    Y191.307 F7
    Z-7.500
    Y194.307
    Z-15.300 F80
    Y210.593 F7
    Y214.595
    X106.079 Y216.285
    X105.332 Y219.142
    X104.163 Y221.854
    X102.598 Y224.358
    X100.674 Y226.598
    X98.434 Y228.522
    X95.929 Y230.087
    X93.218 Y231.256
    X90.361 Y232.004
    X87.424 Y232.312
    X84.632 Y232.181
    X65.256
    Y244.181
    X56.081
    Y215.889
    X60.811 Y215.561
    X68.440 Y212.940
    X75.129 Y208.433
    X80.425 Y202.348
    X83.965 Y195.101
    Z-7.500
    X84.252 Y193.628
    Z-15.300 F80
    X85.509 Y187.184 F7
    X84.951 Y179.137
    X82.329 Y171.508
    X77.823 Y164.819
    X71.738 Y159.523
    X64.490 Y155.983
    X56.573 Y154.439
    X48.526 Y154.997
    X40.898 Y157.619
    X34.208 Y162.125
    X28.913 Y168.210
    X25.373 Y175.458
    X23.829 Y183.375
    X24.283 Y189.925
    Z-7.500
    X24.387 Y191.422
    Z-15.300 F80
    X27.008 Y199.050 F7
    X31.515 Y205.740
    X37.600 Y211.035
    X44.847 Y214.575
    X53.256 Y216.215
    Y244.181
    X44.081
    Y232.181
    X36.669
    Z-7.500
    X33.669
    Z-15.300 F80
    X24.720 F7
    X21.925 Y232.362
    X18.962 Y232.095
    X16.075 Y231.374
    X13.334 Y230.218
    X10.803 Y228.654
    X8.543 Y226.719
    X6.608 Y224.459
    X5.044 Y221.928
    X3.888 Y219.187
    X3.168 Y216.300
    X3.081 Y215.343
    Y210.593
    Y191.256
    Z-7.500
    Y188.256
    Z-15.300 F80
    Y52.233 F7
    Z-7.500
    Y49.233
    Z-15.300 F80
    Y32.541 F7
    X3.263 Y29.775
    X3.814 Y27.005
    X4.721 Y24.331
    X5.971 Y21.798
    X7.540 Y19.450
    X9.402 Y17.326
    X11.525 Y15.464
    X13.873 Y13.895
    X16.406 Y12.646
    X19.081 Y11.738
    X21.851 Y11.187
    X24.617 Y11.006
    G00 Z10.000
    (EndPosition)
    X0.000 Y0.000 Z15.000
    M05
    M30
  30. Metalguru
    Metalguru Veteran
    Yes, that g-code is in metric. If your machine or UGS is set to inches, as it looks like with the G54 values you sent, it will try to go to (the first instruction) X34.405 Y38.500 inches, which will be way off your table. Also, these g-code moves are all positive, which will not work if your Home position is in the upper right corner. All moves should be negative if this is the case. By the way, if you are running in metric, a feed speed of F7, or even F80, is glacially slow. it should be more like F500-F1500, depending on material, bit speed, etc. SketchUCam defaults to the very low speeds, you need to crank it up.
    Did you download Camotics and preview your code? This is an absolutely necessary step.
    I never found a need to use G54, I set it to 0. I use GRBL Panel, and there is a zero button right beside G54 to clear it. I always set my work zero and machine zero by disconnecting and reconnecting after positioning the machine to my g-code origin using GRBL panel. This sets everything including machine position to 0 at the origin of my g-code, and I never have problems.
    I don't understand why GRBL insists on homing to the upper right and having all moves into negative space in quadrant 3. This makes no sense to me, despite the explanation of why Chamnit does this on the GRBL WIKI. Almost all g-code generating software defaults to the origin in the lower left hand corner, with all moves positive in quadrant 1, which makes a whole lot more sense to me.
    MG
    Saint Billy likes this.
