7050 Sphinx
Discussion in 'CNC Mills/Routers' started by Michael.M, Jul 15, 2017 at 7:02 PM.
  1. Michael.M
    Michael.M Well-Known
    Michael.M published a new build:
  2. Michael.M
    Does anyone know the proper amount of tension I should put on the wheels? The eccentric nuts have 6 flat sides and I basically turned each nut 1/6th of a rotation. This made the machine feel fairly solid like the axis wouldn't move if i stood them up vertically. Thanks!
    Michael
  3. Rick 2.0
    Sounds like you have them a bit tight. As a general rule you should be able to grip a wheel and with a small amount of effort be able to have it slide along the track. When released, the gantry should move easily. If the motion is too stiff, that just requires extra effort on the part of the steppers to overcome.
  4. Michael.M
    Thanks Rick! I'm completely new to this type of linear guide. Im trying to make this machine as tight as possible. Hey I have another question: The leadscrews I bought have an OD of 7.75mm and my flange bearings are exactly 8mm ID. There's definitely a wobble there. Is this normal?
  5. Rick 2.0
    Yes that's normal. Some members have used Teflon tape to fill the gap which helps prevent rattling.
  6. Michael.M
    Hey Rick what is the proper way to adjust the eccentrics? Is removal of the carriages the only way? I worry that as I create a tighter fit, the wheels will get damaged when entering the cut end of the extrusions.
  7. Rick 2.0
    Sorry, but I don't really have an answer for that as I haven't built anything C-beam with internal wheels yet. One suggestion however would simply be filing the sharp edges where the wheels enter the rail to protect them.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
