5mm Shaft Collars & 40x40 Fans
Discussion in 'Share Parts' started by AR15DCM, Apr 25, 2016.
  1. AR15DCM
    AR15DCM New
    Hello,
    Just found these 5mm shaft collars tonight if anyone else is interested... 10 pack 5mm Collars for $2.00
    And also 40x40x10 cooling fans for $2.00 each...
    It is from a hobby company named Value Hobby
    While I am sure they are not top of the line, if you are on a very tight budget like me they will get you by until you can upgrade to something better.
    UPDATE:
    I found these at Global Industrial
    #1 AR15DCM, Apr 25, 2016
