3D Printer
Discussion in '3D printers' started by Cuong Vu, Nov 27, 2013.
  1. Cuong Vu
    Cuong Vu Well-Known
    Ridgeback likes this.
  2. blindflight
    blindflight Veteran
    This is a fantastic build in record time for first time build plus you had to engineer the design yourself. Your building skills are great. Really good to see the evolution of the prints to where you have refined them. Look forward to your future builds.
  3. Robert E. Nee
    Robert E. Nee Well-Known
    Great design and implementation.
  4. Cuong Vu
    Cuong Vu Well-Known
  5. rhondaviolachurch
    Awesome build! What are you running it with??
  6. JZatopa
    JZatopa New
    Great build. I am working on something that is very similar. Mind if I asks you a whole bunch of questions :)
    Are you having any z-banding issues?
    Is there anything you would do different if you had to do it over again?
    Your printer is the first I have seen using a metal chain drive, how do you like it?
  7. Cuong Vu
    Cuong Vu Well-Known
    At first I used Marlin firmware and ReplicatorG host for awhile then I tried with Repetier firmware with Repetier host, then Marlin with Cura host, but finally I end up with Marlin firmware and Printrun host.
  8. Cuong Vu
    Cuong Vu Well-Known
    I don't see any problem with the Z.
    I like that way so far, haven't got any issue yet. Right now I just want to make it enclosed so I can control the chamber temperature. So I won't change.
    I tried the belt first on this project:
    http://openbuilds.com/builds/camera-slider-for-stacking-focus.224/
    But I found out it took too much space between the moving plate and the rail, it noisy when running, and need to keep lot of tension to make it run good.
    Then I decided to go with the synchromesh cable. Things I don't like with that cable is the price and not much place sell it. But i love it.
    #8 Cuong Vu, Dec 15, 2013
  9. bill
    bill Well-Known
    What is the approx build area for this setup?
    Assuming the parts from the openbuilds and panucatt get restocked I think I'll be building one based on this design. ( only thing I think I would change is a base to put the power supply and controller in )
    Also curious about your experience with the syncromesh. That seems like some really cool stuff!
  10. Cuong Vu
    Cuong Vu Well-Known
    20140105_175627.jpg The frame I made for X: 15", Y: 10", Z:15"
    But i'm using the short lead screw and small bed 8x8, so right now it can make 8x8x8 max
    The power and the board are mounted at the bottom on the back, they are attached to the frame (see picture)
    With the synchromesh cable, I'm loving it: quiet, smooth, precise, and use less space.
  11. Cuong Vu
    Cuong Vu Well-Known
    Just replied above
  12. CBG
    CBG New
    If you dont mind how did mount the extruder to the vslot carriage.
  13. Cuong Vu
    Cuong Vu Well-Known
    Hi,
    Sorry for the late respond,
    I just cut a V aluminum bar the drill a hole on it to make the bracket to mount
    Cuong
  14. MechEng
    MechEng Well-Known
    Hello,
    I noticed in some of your initial pictures you had a QU-BD style extruder/ hotend mounted, and then when you began printing, you were using a j-head hot end.
    Did the QU-BD style extruder not function very well? I'm just curious why you made the switch. I was looking at buying this extruder/ hotend:
    http://www.ebay.com/itm/0-4mm-Dual-...041?pt=LH_DefaultDomain_0&hash=item51b9c36009
    but I might not if they don't function very well.
    Regards
  15. Tim Petrillo
    How are you putting tension on the v wheels for the z axis? I know you can mount the wheels directly to the extrusion but the eccentric spacers dont look like they fit. The build looks nice as I am building something similar but enclosing it.
  16. Rylan Delap
    I noticed you technically use Qty:6 cast 90 degree corner brackets for the build even though your final result may contain only 4. I also have noticed while attempting to build a similar model that more of the M5 8mm screws are required than your BOM designates. Just a heads up for anyone else trying to put this together.
    Do you have more pictures/details for how you went through the build? I am trying to build the same type of design but I am completely newbie-status and need the "for dummies" instructions.
    #16 Rylan Delap, Oct 16, 2014
  17. A J
    A J New
    Hi, congrats on your build. I've been looking at building one, and was wondering, leaving labor aside, what would it cost ballpark to build one of these babies?
  18. Cuong Vu
    Cuong Vu Well-Known
    Hi,
    It was about $800
  19. A J
    A J New
  20. DarkAlchemist
    DarkAlchemist Veteran
    My I3 Rework is a piece of poo. Very little printing on it with a ton of issues I can't work out (mostly Z and bed related) so my next printer will not have a single printed part on it and this is why I like your design. I want a 3d printer not a reprap.
    The principles of a 3d printer are very simplistic from a design standpoint but getting everything to mesh together with pre existing parts and you don't have a DP and basically just have a 24t hack saw it does make it harder. One thing I would do differently on your design, same as any i3 or variant, is kill the two Z motors. A horrible Prusa design that was. Yes, it should be within acceptable error but eventually it has to be tweaked then eventually tweaked again and again and again, etc... A few people have went to lead screws and one belt driving both sides and they never have to touch Z again.
    How did you get the bed to fit? Closeups of the parts fitted together (like the extruder and the bed) would have been great. Basically this is a cool project but you did not give enough information, or detailed pictures, on what goes where and why stuff was purchased (like Nema 23 threaded rod plates (link you provide takes me there) when Nema 17 motors are used).
  21. Chazz
    Chazz New
    I'm trying to replicate your build. What lengths were the 3 linear rails cut to?
  • About Us
  • Like us on Facebook
    Donate to FairShare!
