1000mm X 1000mm with tinyg
Discussion in 'CNC Mills/Routers' started by gazingm42, Feb 26, 2017.
  1. gazingm42
    gazingm42 Journeyman
  2. jamesdjadams
    jamesdjadams Veteran
    Hi, I'm using TinyG as well.
    Do you mind sharing your configuration ($$ command)?
    Thanks,
    -Jamie A
  3. gazingm42
    Jamie. I will when i get back from a business trip on Wednesday.
    The major change i had to make was on the motors tr settings. ie $1tr
    It was set at 1.250. I had to delete something me trial and error testing. Using universal g codr sender i would jog it 10mm. Change it and measure again. It finally worked for me i beleive at 6.850
    Now it cuts spot on for me using a raspberry pi 3 with json running in the garage.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
