Beginner Nightstand Organizer
Average User Rating:
  • Machine Type:
    CNC Router
    Software:
    LaserWeb4
    Machine Time:
    20min
    Bit or Laser Size:
    1/8"
    Materials:
    MDF 1/2" or any other material by just changing the interlocking groove
    An easy to do project that will give you a small place to keep of your stuff at night.
    All you need is about 350mm x 250mm of your favorite material and less 20min to cut.
    **Mind that if you change the material thickness you'll need to modify the interlocking groove.
    Included files are:
    - SVG if you want to make changes to the design
    - LaserWeb4 workspace for an easy load and cut solution. To learn more about LaserWeb4 go to www.cncpro.co
Share this Item
MaryD and Alex krause like this.
