Intermediate Makersl Msl-10 Co2 Laser Flow Meter
Average User Rating:
  • Machine Type:
    Other Machine
    Machine Time:
    Various, total fabrication time about two hours
    Bit or Laser Size:
    1/8" Single Flute End Mill
    Feeds & Speeds:
    Sorry, it's been too long to remember :-(
    Materials:
    Body: HDPE, Cover: 4mm Acrylic Sheet, Gasket: Craft Foam (Walmart), Spinner: ABS Filament
    I designed this for my Gen-4 Full Spectrum Hobby Laser. I wanted to be able to monitor coolant flow and didn't like the larger version sold on the likes of Amazon. This pretty compact, and uses pretty standard "maker" tools and materials. I think it could all be 3D Printed even though I CNC Machined the body (two setups). It was a quick little project only taking a couple hours to complete. The barbs for the two coolant connections are press if plastic double barbs, I believe they were ├ś0.250". Make the two holes the size required to press in one side of the barb, leave the inside portion long as it can be trimmed to fit the inside hole perfectly :)
    I have attached Step files, but would be happy to export into STL or whatever anyone might want!?!?
    Here's a short video of the working as well as a couple quick photos...
Share this Item
Brian Bland and MaryD like this.
