Beginner Driver Board Holder For V-slot V2
  • Machine Type:
    CNC Router
    Bit or Laser Size:
    1/8"
    Materials:
    1/8" plexi glass
    Driver Board Holder
    Here is a simple plexi mount for a driver board holder. Right now I have the hole pattern for the xPRO driver board on it but there are many boards that this could hold by simply drilling the new holes. to suit the board you want to use.
    - Where the circuit board mounting holes are I set the drill depth very shallow only to mark the holes position in the plexi glass.
    This allows me to go back and drill/tap these to M3 screw size for mounting the board.
    - The M5 slots in the center allow you to mount the plate horizontal or vertical anywhere along V-Slot.
    - You will need a (2) M5 x 8mm screws as well as (4) M3 x 6mm screws (2) Tee nuts or drop in tee nuts or spring loaded tee nuts.
    Mounting electronics to your builds is easy now with this simple solution!
Share this Item
  1. Rick 2.0
    So when do we get to see the rest of the new mini mill? :)
    1. Mark Carew
      Soon :) we are working on the final design an build video now. Have one more section to film and edit and then we should be good to go! Super excited about this one
      Mark Carew, May 10, 2017
