43mm Spindlemotor mount e.g. Kress 1050 Current Version Aug 2016
Z-Axis Spindlemotor Fitting
  1. Iwan Müller
    this Stl-File is tought for 3D Printing, but of course milling from a aluminium block would be even better.
    I use the Kress 1050 Spindle with a norm 43mm fitting. The 4 cylinders on the side fit into the three way cube corner connector from the OpenBuilds Part Store which then be fittet on a V-Slot 20x80. See picture IMG_1223.jpg
Recent Reviews
  1. Mitchell Taylor
    Mitchell Taylor
    Version: Current version July 2015
    Well thought out just needs bolt holes for mounting to t nuts but easily drilled
  2. Mark Carew
    Mark Carew
    Well done! I like the way it mounts into the cubes for added support. Great model thank you for sharing
