      I don't know if I will build this, However I thought others may be interested. Just a simple workbench using a number of V-slot sizes. with a replaceable work surface / adjustable lower shelf / good useable size but not to large. Depending on your resources aluminum plate brackets might be a cheaper solution for connecting the front/back and side braces.
      Table is built from the following Openbuilds parts
      20x20 V-slot
      20x40 V-slot
      20x60 V-slot
      20x80 V-slot
      M5 low profile bolts
      90 degree connectors
      See uploaded bill of materials or skecthup model for cut lists and numbers. I hope this is useful or inspirational.
      Keep building guys..
      MFCarew, Skyjammer and Mark Carew like this.
    1. Build Author , Find all builds by Kyo
    I need a new work bench, While considering my options I wanted to see what I could do using V-slot.
    My past workbenchs
