      1 votes
      Hello,
      This is my first attempt to build a CNC Table. I am a sign maker by trade and thought it would be fun as well as useful to have this machine in my shop.
      I intend to make it with a 3'x4' tabe bed, with the gantry spanning the 3' width. I have a 4'x8' by one inch PVC sheet that I am making it from.
      Once I cut the pieces on my table saw I intend to use a special PVC glue as well as screws to put the body parts together. I believe using the 1 inch PVC should give this machine plenty of rigidity and strength.
      My first purchases will be the Side mount linear rails for all the guides as well as the V-Wheels.
      I am trying to see how cheaply I can build this machine while maintaining a high degree of overall durability and precision.
      At the moment I plan on having all the moving parts be belt driven. I have been using vinyl plotters that are belt driven for many years. I believe belt driven machines are very durable as well as accurate and very maintenance free.
      I have yet to decide exactly how I want to mount the stepper motors. I'm thinking of making the bottom deeper and mounting two motors with belts on a cross beam on the bottom as to keep the gantry belts hidden and free of dust. I plan on using two drive belts for the gantry with two stepper motors. (Any Suggestions are more than welcome.)
      Well, that is where I am at at the moment. i still have tweeking to do to the Sketchup design. By the way, I am a huge fan of Sketchup. It is very easy to design in and it is free. No better way to design and redesign before you cut a thing.
      Update: I have done some more adjusting to my design to allow for my belts and pulleys. I will be using 90 degree stepper motor mounts.
        Any suggestions would be very much appreciated.
      Ricardo Almeida and kram242 like this.
    I am building this machine for fun as well as to educate myself in CNC Mechanics.
    1 1" buy 4'x8' PVC Link
    0 Link
    4 Motor Brackets Link
