      So, the build starts with a 20mm X 80mm X 500mm v-slot extrusion. IMG_0518.JPG
      Add a second one...
      These will become the bed.
      Bolt them together with some plates.
      I used a couple of C profiles for the ends. One of them has been drilled to allow the drive shaft to pass through.
      I used a Nema 17 sized stepper motor with integrated tr8 8 shaft from Pololu.
      And at the other end is an 8mm bearing in an OpenBuilds housing.
      The C profiles are bolted to the bed with angle brackets making sure everything is square. On the sides are 20mm X 40mm X 500mm extrusions attached with angle brackets. Make sure to fit the drive nut before putting together the ends.
      So the next step is to fit the X-large build plates to run on the side rails and fit a cross beam to connect both sides
      The Y gantry will be 20mm X 80mm extrusions bolted to each side. This is just a proof of concept and may eventually change.
      This is the state of my build as of 5/12/2016.
      Moag and Mark Carew like this.
    I like CNC machines.
