      So far this is pretty much where I plan to keep my ideas and get feedback, I will update with a cad model after new years and am hoping to have the build operational by march. To achieve this I will be using as many bolt together bits as possible including parts from this site, laser cut parts and interesting combinations of bit and pieces such as rc car tie rods, fishing line and I am assuming an open source Arduino library or similar can be easily adapted to my needs.
      Before rating please let me get some more stuff up :) Doing full time vocation work i needed some motivation to get started... Tho might be making some useful contacts :p
        Pictures of my proposed thesis at...
        https://www.dropbox.com/sh/j4i9uypa0fvmfe5/aZVUFXoAAP
        Note that the propellers are 14" dia (I have been offered prop's, motors and driver's by my supervisor) and I would like to print the ducts in one piece, Comments note required, advice accepted, this is a model done in Inventor by myself, it is an image to show my idea... thus super rough and not yet engineered in any way.
    Requirement of a larger print area.
    Delta Printr, Kossel Pro
    12 Tie rod end http://store.rc4wd.com/High-Precision-Billet-Tie-Rod-End-... Link Billet tie rod, hopefully a bit nicer than the traxxas ones that people have been using
    0 Main Framework http://openlab.com.au/shop/v-slot-20-x-60/ Link Aussie store with most of the open builds stuff, hopefully everything I need. Ill get back to you on how much I use.
    4 Stepper http://openlab.com.au/shop/nema17-stepper-motor/ Link
    3 Rod length http://australia.rs-online.com/web/p/threaded-rods-studs/... Link
    0 Link
