      3 votes
      Mini Kossel V-Slot 3D Printer
      Nothing quite captures the imagination like a Delta type 3D printer in action. The UltiBots Mini Kossel V-Slot is a fun kit to build and print from. This kit uses a PG35L geared motor directly mounted to the effector. Our Micro Extruder is compact, lightweight, and proven. It is unlike Bowden Tube style exctruders because the filament is fed directly into the HotEnds J-Head. Together with V-Slot extrusion and wheels this kit is straight forward and less complicated to build compared to cartesian 3D printers. NOTE: this kit does NOT include printed parts. You will need to supply your own. STLs found on https://github.com/UltiBots/MKVS.
      Specifications
      • Full Height Print Area (XYZ) = 160mm x 160mm x 180mm (6.3" x 6.3" x 7.1")
      • Useable Print Speed: 150mm/sec (7.9in/sec)
      • X Y Print Tolerance: 0.0125 mm (12.5 Micron)
      • Layer Thickness: 100 – 400 micron depending on nozzle (.1mm - .4mm) (.004" - .016")
      • Supported Filament: 1.75mm & 3mm ABS and PLA plastic filaments
      • Overall Dimensions (WDH): 320mm x 360mm x 615mm (12.6in x 14.2in x 24.2in)
      • Weight: 5kg (11lbs)
      • Power Requirements: 110 - 220 VAC, comes with USA power cord
      • Maximum operating temperature: 240C Extruder & 120C Heated Bed
      This Mini Kossel V-Slot Kit uses top quality components including:
      • V-Slot Aluminum Extrusions (x3) (OpenBuilds.com)
      • Misumi Aluminum Extrusions (x9)
      • Goodwinds 0.230 Inch Outer Diameter Pulltruded Carbon Rods
      • Traxxas 5347 Ends
      • Misumi T Nuts
      • HotEnds.com J-Head Mk V-BV
      • 200 watt 12v Kapton heater
      • Wei Hao 12v 29a Power Supply
      • Borofloat Borosilicate Glass
      • Gates GT2 Belts
      • eMinebea PG35L Micro Extruder Motor
      • Kysan NEMA 17 Stepper Motors
      • Arduino MEGA 2560 V3 + RAMPS 1.4 (Taurino Compatible)
      • Pololu A4988 Stepper Driver (RepRapDiscount Compatible)
      • Ultipanel LCD Controller (RepRapDiscount)
      • McMaster/Fastenal Stainless Steel Hardware
      This kit in addition, includes:
      • Pre-terminated wiring with braided sleeving
      • 3 endstop kits
      • Extra connectors and heatshrink for customization
      • 3 cooling fans
      • Power cord, receptical, switch & wiring
      • USB 2.0 cable
      Visit http://www.ultibots.com for Mini Kossel V-Slot, MendelMax & UltiMax Kits, Printed Parts, Delta Components, Filament, Electronics, and More...
      Most current STLs are found here https://github.com/UltiBots/MKVS
      See more of UltiBots Designs at http://www.thingiverse.com/UltiBots/designs
      Example photos are here:
      You, Marconium, LSDMD and 9 others like this.
