Build List
Build Author Elias Ramburger Views 108
600 volume 3D-Printer
Build Author OpenBuilds Views 16316
BlackBox X32
The next level of CNC motion control solutions. Packed with advanced new features and built on the reliability of the proven BlackBox system
Build Author Retsaj Views 49588
Build Author Michael.M Views 34583
7050 Sphinx
My Lead 1010
C-beam Machine - Modesty
Build Author Joe Young Views 10597
Rack and Pinion (Death to Belts)
Low profile rack and pinion linear actuator design
Sphinx 66
Build Author Quentin Karmark Views 5162
Laguna Swift 4X4 CNC mill retrofitted with OpenBuilds
Used Laguna Swift 4X4 CNC mill with Water-cooled Spindle and RichAuto serial pendant retrofitted with OpenBuilds/Blackbox/Interface
Techsoft Roland TS-30 rebuild
Openbuilds 4x8 cnc
Build Author Mark Carew Views 18218
Build Author OpenBuilds Views 21929
INTERFACE CNC Touch Control System
Super cool standalone Human-Machine Interface for controlling your CNC machines!
Build Author StrictlyScale Views 6170
Lead1010 Build with Enclosure
First time CNC builder puts together a Lead1010 machine.
Build Author EvanH Views 597
Build Author Keith Davis Views 19071
Vulcan MAX
5'x10' CNC Plasma/Mill Table
Plasma Mill CNC
LEAD Lathe
Build Author Bob Darrow Views 5867
BA3DP
modifying ACRO
"Hirata scrap find" CNC
First CNC and first attempt at building one also, so yeah... good luck to me!
Z Floating Head
KRE CO2 2x4 Laser
Large Format CO2 Laser Cutter
Build Author Mark Carew Views 72581
Build Author Mark Carew Views 56878
Build Author Kyo Views 21442
Sphinx 55
Build Author cdsmith12 Views 23774
Build Author openhardwarecoza Views 70794
openBuilds FreeBURN-1 V-slot CO2 Laser (60-100w)
DIY Lasercutter: Budget orientated, medium sized (60-100w), safety first, based on Lasersaur software toolchain
Build Author Spark Concepts Views 12948
CNC xPRO V4
Take your build to the next level with the CNC xPRO V4!
cnc back stop for brake press
back stop build
Build Author Troy Proffitt Views 23218
Hydraulic lifting table
Build Author Mark Carew Views 116323
C-Beam™ Linear Actuator
My large machine 48 X 48
Build Author Frank Del Favero Views 5006
Build Author Mark Carew Views 176267
LEAD CNC 1010 (40" x 40")
Build Author sausagePaws Views 71985
Build Author Ryan Lock Views 121506
WorkBee CNC Machine
Build Author CONUCON Views 2410
3DTwinX Gantry CNC System
Belt driven 3-axis linear system for high precision and low costs. > Threading and linear real cutting needed
Build Author Mark Carew Views 27326
High Z Mod for Lead CNC
LR/BS CNC Router
An easy to source/easy to build, yet quite robust CNC router. This design has not yet be implemented.
Build Author tshilling Views 30983
Build Author Mac6986 Views 14658
Build Author Ryan Lock Views 128567
Ooznest OX CNC Machine
Heavy Metal
Build Author Gerald Klein Views 12921
Reworked Sepcraft 420 CK
Its alive !
Build Author Kyo Views 29070
Sphinx 1050
Salmon Sphinx 1.0
Build Author Suhmanda Views 1836
DIY CNC SPINDLE
CNC SPINDLE FOR DIY ROUTERS AND MILLING MACHINES ITSRS-985 MOTOR HAS MUCH BEFINITS THAN ANY OTHER DC MOTOR IN MARKET
Build Author Scott Drake Views 12941
1500x1000 CNC Router
Gauthali V2.0 DIY 3D printer
Build Author alan richard Views 44792
Core-XY Cube
Build Author Rob Taylor Views 15230
M4: 1510SS Heavy Mk.I
Build Author Keith Davis Views 31946
OneZ i3
Build Author jaron kennell Views 3526
Rezo 1390 100W CO2 Laser
TrueUp Bold
Pneumatic cnc cutter with festo drive
CNC Glass cutter
CNC Cutter Knife
CNC knife cutter with loline blades
CNC Linear Slide for DIY project
Low cost cnc linear drive for making any xyz cnc structure
Plasma Table 006
Build Author Mark Carew Views 251386
C-Beam® Machine - Plate Maker
Build Author Mark Carew Views 13000
C-Beam XLarge X/Y Table
Build Author Ryan155 Views 8092
RIGCNC
I made a mill from first principles because I didn't like any of the ones that were out there, More info can be found on the website RigCNC.com
Build Author OpenBuilds Views 11925
C-Beam® Tension XL Linear Actuator
Build Author that-jim Views 6612
Z-Axis Upgrade For My Sphinx
Build Author that-jim Views 40617
Build Author MattR Views 16220
Build Author Damian V-SLOT Poland Views 1631
LEGO BOX
Build Author OpenBuilds Views 17661
OpenBuilds Table Series
The OpenBuilds Table Series offers a modular table structure that grows with your needs.
My ACRO Build
An ACRO laser put together with some repurposed and some new parts.
Build Author Mark Carew Views 67688
OpenBuilds Workbee 1010 (40" x 40")
The OpenBuilds WorkBee 1010 - 1000x1000 Lead Screw Driven CNC Machine
A Rolling Plotter
Project Completed.
Build Author UltiBots Views 33866
UltiBots CB3030 CNC Router
Build Author Yanou Fishel Views 7806
Beefed up Minimill
C-Beam Machine XLarge
A rigid and wide format, plate and carving CNC.
Build Author Sigifredo Cruz Rojas Views 2389
ALl included interface
Build Author 2SIsurf Views 4104
Hotwire cnc Surfboards
Xl 2 axis foam cutter Eps Surfboard blanks Simple open concept but high production machine. Shape 3d case with open builds controller
Simpl3rBot
A framing design for cantilever style printers
Build Author Jason Moore Views 9598
Lead1500 Plasma Table w/THC
Denford CNC Resurrection
Denford CNC Mill Update
Build Author wackocrash5150 Views 16732
45W CO2 Laser Build
Y-1200 co2 laser
Y-1200 Build The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm. The recommended power output is 60-90W, this can also be increased with the use of an extension box. designed by furtherfabrication ROB CHESNEY FREELANCE INDUSTRIAL DESIGNER.
Monster-not-so-mini-mill
My Minimill hit the gym, and isn't so mini anymore
Custom 4x4 CNC
I started designing and ordering parts for this build back in Oct 2021. Unfortunately life got in the way and I had to sideline the project to deal with more important projects. I am now back working on this project full time. I originally was building a MPCNC on this torsion box platform I built but quickly realized how difficult it would be to produce anything with good accuracy. So I decided to design my own CNC that would be more robust and accurate.
KillerBee 1515 customized
Killerbee 1515 with modifications.
Build Author alex_b Views 16283
TACIT RONIN CNC - Flood Coolant Enabled C-Beam
The TACIT RONIN CNC is a fully enclosed C-Beam platform intended for flood coolant cutting of Carbon Fiber and G10 composites.
T Nut Holder for V Slot
This is a T Nut Holder for OpenBuilds V Slot System. Useful when you want to keep t nuts in place, for example when you're mounting something vertically.
Build Author Mark Carew Views 204203
OpenBuilds ACRO System
The OpenBuilds ACRO System was developed to be the most accurate and cost effective positioning system in its class. The ACRO System incorporates the OpenBuilds V-Slot system and, therefore, has the unique ability to expand to multiple sizes creating a size configuration custom to your needs. Choose the size that best fits your workshop. This versatile system allows for precise positioning of many different mountable tools and attachments.
