      This is Ike:Laser, something I have been working on for a few weeks.
      Over 98% of the parts are from the Openbuilds's store, I used left over parts from previous builds such as Misumi T-Nuts and Misumi Cast Corners, but I could have use the one in the store.
      The only parts that are not in the store are the Shapeoko style belt clips, which I got from Inventables.
      My original design was to use 1/4in thick UHMW Polyethylene Sheet, however, after 3D printing the Y axis parts on my 3D printer for test fit, and subsequently milling the same parts on my Shapeoko 3, I figured the polyethylene sheet at 1/4in had to much flex in them.
      So, I decided to get the plate laser cut. I might have done those on my Shapeoko, but I have no experience in milling aluminum, hence instead of wasting mucho deniro learning how to mill alu, I went the easy route. :D
      What you see here is the result as it stands today. I am still debating whether to use the Shapeoko style belt clips or revert back to use T-Nuts, or something.
      The machine feels quite sturdy. I am happy with the result so far, and the manual Z axis for adjustment of the laser head (it was designed to use a 3.8W JTech Photonics laser head) is quite nice. I decided to have a manual adjustment of the laser height instead of messing around with the focusable laser lens.
        My next step is to hook up my smoothieboard and work out the kinks.
        After that, I'll look into what type of laser that is compatible with the smoothieboard I want to use.
