      1 votes
      Full details on my website http://www.rckeith.co.uk/cnc-detailed-build-and-plans/
      The build of the CNC hot wire foam cutting machine isn’t difficult just measure twice and cut once as the saying goes. The website has the build instructions, plans and main parts you’ll need as well as the cutting lists. The controller board and the stepper I’d recommend you buy as a kit including the power supply. Loads on Ebay, just search for a 4 axis CNC kit. I’ve included all the details of my machine so if you follow this you should be able to build your own.
      yakeen, Skyjammer and silopolis like this.
    Hot wire cutting by hand is OK but requires many templates which take time to make. So I built this CNC hot wire foam cutter to eliminate the templates. I always wanted to build a CNC machine but never though it possible. If I can do so can you.
    Youtube seeing what was possible.
