      1 votes
      I'm calling this the C-Beam 2XL since I doubled the cut area.
      Instead of the 500mm C-Beams for the Y axis I went with 1000mm C-beams and a larger MDF base board.
      Some details
      - Mach3 control software
      - Mach3 breakout board
      - TB6600 motor drivers
      - Dewalt Router
      I built this mostly to cut aluminum plates and after the first few cuts I can say I'm extremely impressed with the cut quality and the accuracy of the parts. (I regularly use a Waterjet so I have a comparison and I will be now using this instead for most parts)
      Also of note I'm cutting aluminum at 30 ipm and have ran it up to 45 ipm with a cut depth of .03.
      Update: I've now replaced the MDF platform with a 3/8" aluminum plate. Seen in IMG_6857.jpg
    To cut aluminum parts.
    C-Beam XL Machine
