      This is an ultra low cost build. I found a pile of apple crates for sale at a local hardware store. I then used 14" drawer sliders for the Y axis table. The controller is an Arduino UNO with the Protoneer shield, running GRBL. Everything else is sourced from OPBS. You can use this as a router, mill, laser gantry or a Z axis for an SLA 3D printer!
      Supplier Item Cost Qty Total
      Home Depot Wood Crate 11 1 11
      Home Depot Drawer Slides 12 1 12
      Home Depot 1/2" 2x2 Plywood 6 1 6
      Home Depot 3/4" 2x2 Plywood 8 1 8
      OPBS Spindle Mount 30 1 30
      OPBS 20x40 V Slot Rail 6.5 2 13
      OPBS Black Corner 2.75 2 5.5
      OPBS L Bracket 1 2 2
      OPBS VSlot Gantry Plate Uni. 12 2 24
      OPBS Threaded Rod Plate Nema 17 6.95 4 27.8
      OPBS Eccentric Space 6mm Full Size 2 4 8
      OPBS Tee Nut M5 4.95 1 4.95
      OPBS Lock Collar 8mm 1.1 1 1.1
      OPBS Slot Cover 2 2 4
      OPBS 5mm to 8mm flex coupler 6.35 3 19.05
      OPBS 8mm Acme Screw 250mm 10 1 10
      OPBS 8mm Acme Screw 500mm 20.75 2 41.5
      OPBS Nema 17 17.5 3 52.5
      OPBS Metal V Wheel Kit 9.75 8 78
      OPBS Ball Bearing 8x16x5 1 1 1
      OPBS Nut Block 8mm 6.96 2 13.92
      OPBS 2 Hole Strip Joining Plate 1.95 2 3.9
      OPBS Spacer Block 3.95 2 7.9
      OPBS 40mm spacer for motor 0.75 9 6.75
      Protoneer Motor Driver 20 1 20
      China Arduino Uno 3 1 3
      Ebay Pololu 4988 3 4 12
      Total: $426.87
