      This is my OX CNC mill. I actually used a smaller CNC that I had made (this is Grandpa! IMG_20141225_130835_170.jpg ) to cut out the plates (Side and Z axis) out of 1/4" acrylic IMG_20141225_130756_483.jpg . Then I used the OX to cut out another set of plates out of acrylic that were more accurate (OX with the acrylic plates! 2014-05-05_10-05-03_223.jpg ) . Then I used the OX with the better plates to cut out new plates out of T6061 Aluminum IMG_20141215_160807_475.jpg ! I also made the side plates a little taller to give me more room when using a longer bit IMG_20141215_163814_671.jpg .
      The cutting surface is 1" thick MDF. I used the OX to drill holes in an alternating 4" spacing pattern. I then hammered 1/4-20 furniture nuts from under it IMG_20141220_201638_363.jpg . This allows me to use my home made clamps IMG_20141225_130715_800.jpg IMG_20141225_130733_414.jpg IMG_20141225_130737_039.jpg !
      I didn't like the way the original OX held the belts in place. It ended up putting a hole in the belts and weakened them. I decided to go with the crimps that make a loop out of the end. I figured that would keep the belts as strong as possible. I then had to come up with a way to mount and tighten them. This is the stationary mount on the rear of the machine IMG_20141225_130640_071.jpg and this is what I came up with to tension the belts IMG_20141225_130651_000.jpg IMG_20141225_130700_424.jpg . If the belts ever stretch out, I can just tighten it up, or if I've reached the maximum, I can add a few washers/spacers to the back side! The pegs you see are for the limit switches.
      So here are some pictures of the finished project! She is strong enough to mill aluminum and accurate enough to do isolation routing of printed circuit boards!!!
      IMG_20141221_130001_488.jpg IMG_20141221_130003_083.jpg IMG_20141221_130010_705.jpg IMG_20141221_130023_138.jpg IMG_20141221_130033_393.jpg
      I also used a 1" diameter routing cutter to cut out a small amount of the tables surface to ensure that the cut out area is exactly parallel to the x and y axes. My cutting envelope is 20.3439" x 18.3618" (I could probably squeeze out a little more by moving my limit pegs... :)
      My next upgrade will be to replace the delrin wheels with polycarb or even steel.
      Here are some links to the controllers I am using:
      http://xylotex.netfirms.com/OSComme...id=92&osCsid=b41489ba9430b62e53f9ef3c1ec6d4d8
      http://xylotex.netfirms.com/OSCommerce/catalog/product_info.php?products_id=88
      http://www.warp9td.com/ (I used the ethernet one and found it on e-bay)
      I hope that you find this build interesting. It was a long time from start to finish (and maybe still not completely finished!! :) ) During the process, I used the OX to do all sorts of different things and I only upgraded it as it was needed. I am so very pleased with the final product! Grandpa was the first CNC mill I had made and OX was the second, (third, fourth, fifth... :) )
      I hope this inspires you to make your own!!
    David Steele (for the build for Grandpa), the OX builders, Openbuilds.com
